Z18 Turbo
Z18 Turbo
I need a sump (bowl at front) for Z18 turbo instal ...any suggestions?
Re: Z18 Turbo
I've got a Z20E sump at home, it's doesn't have a turbo drain fitting that I can see though.
Re: Z18 Turbo
broke wrote:I've got a Z20E sump at home, it's doesn't have a turbo drain fitting that I can see though.
That would work, I can weld a turbo drain into it....how much & where are you based? Many thanksbroke wrote:I've got a Z20E sump at home, it's doesn't have a turbo drain fitting that I can see though.
Re: Z18 Turbo
Thanks, I think that will work, how much & are you ok to courier to fielding
Re: Z18 Turbo
Sorry for late reply, just dug it up now. Looks to be front sump but has a bit of a dent. I'm in Christchurch but can probably courier for around $40 for the part and maybe $20 courier?graveldat wrote:Thanks, I think that will work, how much & are you ok to courier to fielding
Re: Z18 Turbo
Thanks, no problem with dent, I have to make a couple of mods anyway. Can you txt details to 021 563110 & I'll contact you, regards
