Which fuel pump to use??
all your DIY needs
Speed_Freak
aka: Matt
Post by Speed_Freak »
The fuel pump on the coupe was getting noisy and after fixing my leaky tank the fuel pump decided to pack a sad and gave up :guns: . What kind of fuel pump would you guys recommend getting, walbro 500hp etc?? Any to steer clear of? Im gona put in a surge tank fairly soon also so take that into account...
1976 Mazda 808/RX 12a Rotary
1990 Nissan 300ZX Twin Turbo Manual ;)
Re: Which fuel pump to use??
The surge tank wont have much effect on your choice of EFI pump. I'd recommend choosing a quiet lift pump when you do fit a surge tank though.
Dattochriswagon
Post by Dattochriswagon »
I got a bosch 300hp one from jap race for a couple hundy should do the job on my ca so im sure you will be sweet
Josh
aka: SeEn-ThE_lIgHt
Post by Josh »
Bosch 044 will give you all the gas you should need in your car, or Walbro as a nissan-style in-tank replacement.
Ill be going with an 044, but the rest of my fuel system is a bit of a mystery as yet.
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
