So after all that, I had to put it back to how I originally assembled it. My thoughts are, due to the axle being shortened and the reversed eye leaf springs, the assembly like the manual explains just wasn’t going to work. So flipped the axles/ backing plates and all assembled!
But heck the new height looks good
Also put the towball on for the bike rack
In other news, the bearing wasn’t the issue, it was a bent axle so next mission is to source another and shorten it then reassemble.
I will make nationals
