Otodats vb11 rat wagon
Otodat
Datsun Driver
aka: Steve
Re: Otodats vb11 rat wagon
Post by Otodat »
This wagon has passed cert end of last year and is currently road legal, been keeping it local for now but so far hasn't caused any troubles so will slowly increase the radius from home it travels.Its quite good to drive but a bit bouncy, I haven't had a lowered car for a while.
Otodat
Datsun Driver
aka: Steve
Post by Otodat »
Got the heater hooked up for queens birthday cruise. Found Gates 01-0004 to be a good fit. Been trying to get the temp gauge to work porperly, seems to stay low unless in town so tried to shorten the adapter I had made for the sensor
Had thought it may be out too far, it didn't seem to make much difference. Next thought was being on top of the thermostat housing might be the problem but would need to drill and tap into another location in the block, which I didn't have the correct tap for, so left it for now. Taking a long trip first thing in the morning revealed that the engine is definitely running way too cold, so hopefully it's just a new thermostat needed, so that's next in the list.
Otodat
Datsun Driver
aka: Steve
Post by Otodat »
Oh yeah, decided since the bonnet is actually red originally it would suit a japanese flag type of thing but didn't want to go all in seeing as it would be like putting a confederate flag on an American car. Anyway my daughter helped me make this up, painted the bobomb and then masked and used thinners to take the white paint off the top to reveal the red
maddat1
Post by maddat1 »
Bonnet looking good steve
Otodat
Datsun Driver
aka: Steve
Post by Otodat »
This thing has been going well and has made it to a few Datsun events now. Been plenty of little things done to it, the latest being a nos carb.
And I've put air shocks in the rear to help with the variable loads this gets, like loading my family of five plus gear for a weekend away for example, or other general wagon duties...
Also changed the front shocks but this still needs work, rumour is s13 adjustable shocks might fit so have been looking into this as I'm not totally happy with the way it rides. Anyway will try to be a bit better at updates here.
Otodat
Datsun Driver
aka: Steve
Post by Otodat »
Put some new (to me) seats in out of a VW polo, other than that just been driving it. You'll have to turn your phone sideways for full effect sorry :D
Tony_Whenua
Post by Tony_Whenua »
Front and rear matching seats. Shit yeah that’s an epic swap. How does that work for WOF etc?
Otodat
Datsun Driver
aka: Steve
Post by Otodat »
I've used the b11 seat rails in the front and the seat belts aren't mounted to the seats so had been ok so far. I guess it could be a sticking point if they wanted to nit pick.
Steve, is this thing factory GA--DE??, rather DS? Seems rather advanced, the later model got a single cam 12 valve GA in NZ, Carbed and Injected I think. Sorry I should have gone back to see if you have an post on engine swapping it.
Vaughan
Otodat
Datsun Driver
aka: Steve
Post by Otodat »
Yeah it's E15 standard, I swapped it because I found the N14 engines to be far more hassle free.
