Help
- kartboy
- aka: Hayden
Re: Help
just been out for another look and when engine isn't running there is only ignition power to coil but when key is off and engine is running it has power to both sides of coil although negative side is fast pulsing, the charge light is also on on the dash when engine is running.
Re: Help
have you changed your alternator? I had this problem once when I ran an L series alternator on an A series car.
- kartboy
- aka: Hayden
Re: Help
No haven't changed it, it is the one that was on the motor when i got it from south city van spares. Have got a spare couple here though that I could try
Re: Help
Im tending to work on the theory that the carb is the only thing that has changed.
So there for is the cause.
have a read of this
http://en.wikipedia.org/wiki/Dieseling" onclick="window.open(this.href);return false;
have a read of this
- kartboy
- aka: Hayden
Re: Help
I don't think it is dieseling as it runs normally after key is turned off and only stops when it is stalled or I pull the coil lead off.
the engine has been replaced with one out of a '91 vanette, so it is possible that I have f&^%ed up and put something where it shouldn't be or omitted to put something where it should be although there doesn't seem to be any extra wires anywhere
fast4motion
- aka: Brent
Re: Help
If it stops running when you disconnect the coil wire, then it definitely WON'T be fuel related.
I'd suspect the coil is wired up to one of the voltage sense wires for the alternator/regulator. So it's receiving voltage whenever the alternator is running.
- kartboy
- aka: Hayden
Re: Help
I was thinking similar but know the coil wires are connected the same as before. Is it possible that it is back feeding from the alternator somehow??
Re: Help
Put your old alternator back on. Chances are the alternator from the donor van may use the same charging system as a L series car does. They have a diode somewhere in their set up. What letters are on the terminals on the back of the ALT?
