Yep could be the go. Will be keen to hear where you get with it.Godzilladat wrote:I know you have put a lot of work into making it happen with the stock hub & spindle, but I'm hoping I can achieve the same with a replacement spindle.
If I have time this weekend, I will take the whole setup off and take it to a wheel shop to see if there is anything that can fit over it. I had always planned on running spacers so didn't think I'd have an issue. I may still be able to get some 27mm spacers to fit, with modification to the hub, but it is a path I would rather avoid as it could mean modifications to the spindle etc. as well.
