Page 2 of 3
Re: Which late model thin type radiator best suits A-series?
Posted: Sun Jul 07, 2013 8:50 am
competition pads will improve things, BUT be aware that they may need quite a bit of heat in them to get up to optimum braking .
on the road they may not improve things at all, as they will run to cold.
Posted: Sun Jul 07, 2013 4:17 pm
by joelbrown
2 doors wrote:competition pads will improve things, BUT be aware that they may need quite a bit of heat in them to get up to optimum braking .
Yeah man very true, full blown race pads would be shite for road use, the ones he uses are actually a road/race combo.
Far better than mintex pads according to him.
I jst thort it was an interesting idea, ive never really thort of modifying a brake pad to fit
Posted: Sun Jul 07, 2013 5:19 pm
The stock 1200 disc brakes are so shit it aint funny. I wouldn't bother trying to improve the pads in them.
Just do a strut swap, or an S13 conversion. Then find some good pads for your new brakes if you still find you need some.
Posted: Sun Jul 07, 2013 5:52 pm
by joelbrown
Bartman wrote:The stock 1200 disc brakes are so shit it aint funny. I wouldn't bother trying to improve the pads in them.
My ute is a 1990, the calipers are the same as pulsar ones.
I got some s13 discs and calipers (the slightly bigger ones) a few weeks back and will be eventually fitting them, tho i still need to get s13 studs and adaptor plates. My tires run so close to the guards up front that with the extra width that the s13 discs give i will need to get camber plates or maybe switch from 165/70/13 to 165/60 or 175/50
Did you ever end up gttn more adaptor plates made up Bart? ... And have i read sumwhere tht you have a lathe?, might save me attacking the hubs with a grinder
Posted: Sun Jul 07, 2013 6:06 pm
by joelbrown
Just a thort, if i did install adjustable camber plates i would need a cert, but once set i would only ever run them in the same position. - Are there plates available in a fixed increased neg camber position (non adjustable but with more camber) , and if so, would they still need cert? The adjustable ones seem to have durability problems with the bearing anyhow, often wrong style brg for the job
Posted: Sun Jul 07, 2013 9:46 pm
I actually have a batch of plates ready to drill.
Yes camber tops will need cert. new laws mean you can't get cert with more than 0.5 degrees neg camber than factory.
Posted: Sun Jul 07, 2013 10:38 pm
by joelbrown
Bartman wrote:I actually have a batch of plates ready to drill.
Nice, would i be able to purchase a pair please?
Posted: Mon Jul 08, 2013 7:33 pm
Sure.
I just need to make time to head over to the workshop and drill them.
I do indeed have a lathe too. It's not a big job to turn down your hubs too.
Posted: Mon Jul 08, 2013 8:36 pm
by joelbrown
Bartman wrote:Sure.
Mean, the ute will be doin hand stands in no time
Posted: Mon Jul 08, 2013 8:54 pm
by luke
Bartman wrote:Sure.
SO HURRY UP AND TURN DOWN MY FLIPPING HUBS
