620 ute door hinge
Re: 620 ute door hinge
Yeah I think my brother has already been raiding that as he lives in Timaz and has the 620
ThreeBlindNinjas
It's mostly all still there. Some external engine are bits gone, and maybe the front indicators. J15 engine.
How rusty is the radiator support panel, and inner guards? I have a real sweet ute with frontal damage to the rad support and inner guards.
ThreeBlindNinjas
I'll have a look tomorrow, but if it's anything like the outside panels, it'll be shot. I'll snap a photo.
Thanks!
ThreeBlindNinjas
Ok. Left inner guard is reasonably good.
Right inner guard is poos. Can see the wheel. Like everything, could be fixed. Big hole from battery.
Rad support panel is ok, surface rust on top, but no bad spots that I could see, but the rad is still in it, as is everything on the front. I could have missed some.
Can you see any rust down in the bottom of the rad support panel?
How much for the inner guards and rad support? I'd be prepared to cut them off myself. (to get the right parts undamaged)
ThreeBlindNinjas
I'll have a good look at the bottom of the panel for you. I can get the panels off un-damaged!
That's sort of my job...
I'll get a price, and yeah... there is the possibility that you could get them off yourself.
Ideally it'd have part of the firewall cut out. Then I can unpick the spot welds on the ground so as to not get any holes in the tabs which will be rewelded to my cab.
