Page 2 of 2
Re: help with 1963 bluebird
Posted: Mon Dec 30, 2013 11:09 pm
by 63bluebird
The car runs an E1 1200cc engine, was hoping a gearbox from a 410 might bolt straight up or one from a A12?
Posted: Wed Jan 01, 2014 10:17 pm
I'm not sure if the 410 gearbox will fit. Maybe the guys over at ratsun might know if the J's and E's run the same bellhousing?
Posted: Sat Jan 18, 2014 11:31 am
by jeremiahnz
The 410 also ran the E1 1200cc. The 411 went to the J13. The gearboxes are different for both, E1 and J13, but could be interchangeable.
I happen to have both sitting in the barn I think. I'll go check soon.
Posted: Sat Jan 18, 2014 1:32 pm
by 63bluebird
Hi, thanks for that, if you have any luck send me a text on
0212710710.
Posted: Sun Jan 19, 2014 2:20 pm
by jeremiahnz
Looks like I may have 2 x J series gearboxes and one E series. I think they are all 4 speed, but the E series may not have had syncro's for going into 1st gear.
The bolt pattern appears to be most the same apart for an extra bolt around the starter motor position on the J series gearboxes. They appear to be the same length, but the J series box has the shifter positioned further back (possibly as they moved away from a bench seat up front).
From memory the spline is the same on the output shaft between the 2, but is different to the A series.
If you want pics or measurements of anything, just let me know exactly what you need.
Posted: Sun Jan 19, 2014 3:46 pm
by 63bluebird
Thanks for that, any chance of been able to come have a look?
Posted: Sun Jan 19, 2014 5:46 pm
Karls 312 has a badge on the grill saying "FULL SYNCHRO"
Posted: Fri Jan 31, 2014 9:21 pm
by jeremiahnz
63bluebird wrote:Thanks for that, any chance of been able to come have a look?
Yep sure that can be arranged. I'm just up silverdale way so not too far from you.
Posted: Fri Jan 31, 2014 10:56 pm
by 63bluebird
Great couse im in Dairy Flat, give me a text when time suites you.
