Wouldnt mind sticking a set in my stash as well.chris_g1 wrote:I have a set of R31 rear brake calipers and the backing plates as mentioned by Mark that are for sale. I think you bought the heater fan off me a while back too.
The calipers and brackets $100.00plus freight.
Might be cheaper than what Murray will want and with a little time and brake lines and cables from Datsport you will have the satisfaction of doing it yourself.
PM if you're interested.
Anyone know this 1600
Re: Anyone know this 1600
These calipers and brakes are for sale to all.
Nic, as Mark says, there is not a lot of work involved. I think there are pictures and instructions on datsport site but probably on this forum somewhere as well.
You need to obtain discs, brake cables for handbrake and brake lines. Datsport do braided lines for this set up as well.
- SRDATO
- aka: Nic
Thanks mate.chris_g1 wrote:I have a set of R31 rear brake calipers and the backing plates as mentioned by Mark that are for sale. I think you bought the heater fan off me a while back too.
pmed you.
MADDAT SR20DET 510 - Sold
- SRDATO
- aka: Nic
Heres his trademe details hit him up.broke wrote:Putting it back to stock eh? In that case if it's the one with the red doorcards then those don't look stock at all and what's more they're totally ghey and he should fully sell them..
http://www.trademe.co.nz/Members/Listin ... ber=290009" onclick="window.open(this.href);return false;
- SRDATO
- aka: Nic
I have Bart so will collect bits I need and im sure with the help from you and all the other fallas ill have no dramas setting it up.Bartman wrote:I'd leap at Chris' set up Nic.
I have the same stuff to go on the rear of mine one day too.
If you want any advise on it, I have a decent idea on how it's done.
Cheers everyone for the advice/ info.
- hsepwr
- aka: Craig
I done mine, they are a piece of piss and work awesome on my car. If you need any info ring me.
- SRDATO
- aka: Nic
Awesome thanks will do.hsepwr wrote:I done mine, they are a piece of piss and work awesome on my car. If you need any info ring me.
- SRDATO
- aka: Nic
The fun has begun
That's the hard part done.
Be sure to post your progress in your build thread.
From memory, you need to weld up the r31 holes in the caliper mount plates, then redrill the holes to bolt onto the datsun rear arm. It's also possible you might need to file a bit out of the center hole to go over the bearing holder?
You also need to bolt the plate on back to front to how it sat on the R31. And there's a small amount of clearancing to be done on the caliper mount plate so that it clears the arm.
- SRDATO
- aka: Nic
Haven't really got a build thread been too busy building.Bartman wrote:That's the hard part done.
I'll weld up holes and have a mate who's going to mill the centre of the bracket out to fit over the bearing holder to keep it tidy. Also going to replace bearings and seals.
Wasn't aware about bolting the backing plate on back to front, thanks - I'll have to play with that idea, looks like calliper mounts on top of the disc going by what I could find as it hits shock mount one side and arm on the other.
