Hi.
Anyone know who owned/built this 1600?
Has the plate FATSUN
Anyone know this 1600
- SRDATO
- aka: Nic
MADDAT SR20DET 510 - Sold
Re: Anyone know this 1600
Seen it on trademe a few times. I think this was the one with the red SSS interior that I want.
- SRDATO
- aka: Nic
Yea new owners stripping it and putting it back to stock, ca18det motor setup is on trademe if anyones interested - Bolt in setup.
Im after info on the rear brake setup.
Nick , Murray he is good to deal with no problems there as long as your prepared to pay the dollars.........
On a side note I have a chuckle everytime i see his SSS dash surround on trademe for $750 , I can find one complete with all the gauges via ebay cheaper let alone one with Missing bits and hacked up to fit aftermarket gauges. But hes out there to make a few bucks like everyone else.....
Regarding the rear brakes , Assuming you are going go to disc brakes aka r31 rears?
- SRDATO
- aka: Nic
Hi Mark.sr1600 wrote:Nick , Murray he is good to deal with no problems there as long as your prepared to pay the dollars.........
Ive been talking to Murray and planning to buy the rear Brake setup from it but he doesnt know any details on what parts have been used so trying to find some info on it.
Have you done it to your one? I have little knowledge on what I need to do to make the conversion myself so figured buying a completed one would be the easy way round it.
Assuming its a R31 rear setup..........
All thats needed is r31 rear calipers including the brackets from a r31 (solid i think)
See Craig at Proparts in Napier for a new pair of disc's they are resonably cheap and not work mucking around with the old ones. (same as early silvia rears from memory)
The brackets need a little tickle up (find some pics on the net)
Basically enlarge the center hole slightly, weld/re-drill the mounting holes, then a little reshaping on the back to clear the swage on the rear arm.
For a man of your panel beating talent you will eat it in no time.
For the cables buy them from datsport, thought i could get them cheaper here but they were almost double............dont think ill get over that for a while.
- SRDATO
- aka: Nic
sr1600 wrote:Assuming its a R31 rear setup..........
Haha touchy subject is it, Thanks for the info mate.
Putting it back to stock eh? In that case if it's the one with the red doorcards then those don't look stock at all and what's more they're totally ghey and he should fully sell them..
I have a set of R31 rear brake calipers and the backing plates as mentioned by Mark that are for sale. I think you bought the heater fan off me a while back too.
The calipers and brackets $100.00plus freight.
Might be cheaper than what Murray will want and with a little time and brake lines and cables from Datsport you will have the satisfaction of doing it yourself.
PM if you're interested.
I'd leap at Chris' set up Nic.
I have the same stuff to go on the rear of mine one day too.
If you want any advise on it, I have a decent idea on how it's done.
