Original was 400 12s I think, about 50-60mm widespiderwebfx wrote:Can you let me know the factory tyre size of the car?
What brand are the tyres you currently have fitted?
I'll see what technical data I can find for you.
Cheers,
Chris
Cheers,
Chris
Chances are, unless he's running the Falkens, the manufacturer specs of the tyre will be the same as our LVVTA standards. I have a lot of technical data books so as long as he's got a decent brand of tyre (read; not cheap chinese crap) I'll be able to look at the spec. If the spec matches the fitment, I'll scan it as manufacturers spec will always override LVVTA standards.gingofthesouth wrote:I know this is compliance, not cert, but surely they follow similar rules. I don't know, just throwing this out there.
According to LVVTA,
195/50/15 are good for 5.0 - 7.0
Even 205 is too narrow for an 8 inch rim for cert.
http://www.lvvta.org.nz/documents/infos ... _Guide.pdf" onclick="window.open(this.href);return false;
It does, however, say "Additionally, where an LVV Certifier is presented with a wheel & tyre combination which is outside the scope of the tables in this info sheet, LVVTA requires that the guidelines of the tyre manufacturer in question are followed, and verification from the tyre manufacturer is provided..."
Sounds like a last resort and a lot of hassle....
Compliance with standard rims maybe?
210s were on 12" rims I think and at the biggest 450s but yes 155sspiderwebfx wrote:Just did some digging, factory size was either 155SR13 or 6.00-12 depending on spec.
If this is the case, 205/50R15, 195/45R15 and 195/50R15 all fall within the 5% tolerance.
I'd consider looking into the 195/45R15 Falken ZE912's and printing this page and taking it with you.
These will also give you more clearance all round.
Cheers,
Chris
