Naki-Fisher wrote:When you say "welding up your sump" what do you mean? have you placed another tapping point in it or where you doing something a little more tricky i.e. baffles and wings?
If you have welded it and can not see where you have gone wrong easily you may find your problem is a big one and will continue to have leaks as it heats up and cools.
Where you welding using Mig - gas, gas-less, Stick or Tig? or good old Oxy Acctileen? (sorry for my poor spelling)
Sometimes when using Mig it is easier and cleaner to do small short runs than long runs, the easiest way I have found to set them up is get your amps as high as you dare, then play with your wire feed until it sounds good if it sounds like its humming it most probably is.
Keep your tip, welding helmet lenses and everything as clean as, the amount of times I have listened to someone welding to stop them and give a little advice to actually find they can't see anything through a dirty lens is amazing, get comfortable spend some time setting it up and playing with it and your welding will improve 10 fold.
Hey man, thanks for your response. Yes - it is all winged, quite a lot of custom. I had to move it from a front sump to a rear sump. I am using a gas mig, the setup is pretty clean and am welding as high as I can (4 or 5 on a 6 step). It is using .6mm wire. I think a lot of it is probably my welding skills. I don't weld that often.
I ground back a whole lot and rewelded on the weekend which sealed a few leaks. I may have to just rinse and repeat or get someone to do it, but I have tried to DIY to learn new skills through the project, so am keen to make a go at it.
