i need a l18 or l20b.
datman310
Re: i need a l18 or l20b.
Post by datman310 »
exactly what happened to me, did a bit rev in 1st then changed to 2nd and knock knock knock kncok knock and i thought FARK i killed it, towed it home, next day pulled starter off and flywheel was loose as a goose, took box out, locktite the bolts back in and she sweet as
2 doors
Post by 2 doors »
yep thats what happend to me, exept I pulled the motor and stripped the crank from the block with the flywheel attatched, it took days before we realised the flywheel was loose, starter out is a great idea.
mint16
aka: Brendan
Post by mint16 »
do you folks loctite your flywheel bolts??
i do and have never had any issues with loose flywheel bolts.
Speed_Freak
aka: Matt
Post by Speed_Freak »
I have never loctite'd them after the a**hole of a job we had on a CA with snapping them while trying to remove them after being loctited in. Although Ive never touched the clutch/flywheel since I bought the motor so it is probably a loose flywheel. Ive never ever heard of an Lseries spinning bearings or anything, even the crank and bearings out of my 200,000km+ L18 was still like brand new
1976 Mazda 808/RX 12a Rotary
1990 Nissan 300ZX Twin Turbo Manual ;)
mint16 wrote:do you folks loctite your flywheel bolts??
I do with the a series motors. The pcd is too small, and the bolts don't have a snug fitting plain with dowels the flywheel onto them.
mint16
aka: Brendan
Post by mint16 »
matt, some people may go overboard with the loctite, and youve witnessed the result of that, and i dont envy what you had to deal with.
only a small line down the threads is enough to secure the bolts.
sam910
Regular
Post by sam910 »
thts wat happend ... i was gutterd i hav a motor lined up tho... $700 l20b stock standerd aparnt low ks and freash rebuild ..
i havnt even looked at my 910 or the l18 since ... to sad....
dattohorder
Regular
Post by dattohorder »
yea i had a flywheel cum loose 2 knockd like botm end
it bent my crank :(
