D1RTY6's C331 Gloria
D1RTY6
aka: Nathan
Post by D1RTY6 »
DJZ wrote:Good job man, good to see it going again. I've got a proper socket for undoing the filler bungs if you want to give it a go sometime.
Yea pretty happy! ha the bung is well beyond being able to be undone, its almost a circle.
brocky41
aka: Brocky
Post by brocky41 »
Well done dude - those bungs are shit at the best of times especially when they are as old as they are now.
85_Z31
Post by 85_Z31 »
Good Work Nathan, Bring it to some meets!
D1RTY6
aka: Nathan
Post by D1RTY6 »
85_Z31 wrote:Good Work Nathan, Bring it to some meets!
Cheers James, i plan on it. hoping for the south cruise if i finish all the little things i need to do before then.
Good man, be great to meet you and see this beast on a cruise again. Will be interesting to compare performance between 2l and 2.6. All the best with getting it sorted.
D1RTY6
aka: Nathan
Post by D1RTY6 »
From the little drives i have had :burnout:, i couldn't really tell any difference between them, in saying that it has been sometime since i last drove it with the 2L in it, however im not expecting much ha
Things that i need to fix before the southern cruise
  • Window wipers - Fuse is ok, wipers arent getting power (controlled by the ECU??)
    LHS indicators - Bulbs are fine, turn on and stay on. no flashing RHS works fine
    Alternator - Not charging, going to go over wiring again
Things that need to be Fitted/removed
  • EFI fuel pump to be replaced and rewired with the one out of the 260
    Choke
    Remove Existing ECU loom and unnecessary wires.
Any ideas on the problems? ideas welcomed
Nathan
Lang2
Post by Lang2 »
re: the indicator, check that indicator flashing relay under the dash/ clean up terminals/ change it. It played up heaps on my 140j first time round
z181200
Datsun Mad
Post by z181200 »
What about pouring the oil in through the shifter hole?
D1RTY6
aka: Nathan
Post by D1RTY6 »
z181200 wrote:What about pouring the oil in through the shifter hole?
Gearbox oil is in, unfortunately it cant go through the shifter
D1RTY6
aka: Nathan
Post by D1RTY6 »
Lang2 wrote:re: the indicator, check that indicator flashing relay under the dash/ clean up terminals/ change it. It played up heaps on my 140j first time round
Had thouht this, will have a look in the weekend thanks :)
