Datsun 260c
- Ivan
- aka: Ivan
Re: Datsun 260c
Hi guys.I've finished painting the front grill and head light surrounds.I think it looks really good.I have to modify the headers as they fowl the steering rods.No biggie and also i have the fuel lines to do before i can start her up.
Datsun 260c
Re: Datsun 260c
The under bonnet paint job is a nice touch Ivan!
- Ivan
- aka: Ivan
Re: Datsun 260c
Yes i wanted to to have some thing that yelled "im from Japan" with out being over the top as i still wanted a clean looking car as with my other cars.
Datsun 260c
- Ivan
- aka: Ivan
Re: Datsun 260c
Hmm tried to start the Cedric today.Didn't happen.Got fuel to the carbs,good spark.Timing must be out.I'll check that tomorrow.If anyone can help that would be great.
Datsun 260c
- Ivan
- aka: Ivan
Re: Datsun 260c
Hi guys.Today i welded and fitted my 2.5 inch exhaust today.I am pleased with the outcome.A lot of you will think a 2.5 inch exhaust is too big for a NA 2.8L six.But this motor will not be in the car long as i will be building a 3.1L stoker for it some time next year.The rear muffler is very easy to take off as i may want to run a Boso style tip on it some time.I just need to weld the pipes above the diff which will pull the rear muffler straight.I also need to buy a fuel regulator before i can start her.
Datsun 260c
- Ivan
- aka: Ivan
Re: Datsun 260c
Been busy today,striped the two front guards and boot to bare steel and painted them with a 2pac resin type paint.Bought a Holley 1 to 4psi Fuel Pressure Regulator and fuel pressure gauge.Tryed firing her over still won't start.I am so stumped.Timing is spot on,good spark.Any one have any ideas? I am using the mechanical factory fuel pump i know its not ideal but it should still start the motor.
Datsun 260c
Re: Datsun 260c
Hey dude - you may have installed the oil pump 180 degrees out - and you will have to drop the oil pump etc and turn it round - this will turn the d around that the dizzy sits in 180 degrees aswell.
Theres a vid on you tube about l series engine rebuilding that shows it.
Double check plug leads are in correct order as i find with these just 2 leads around the wrong way and they dont even fire up on 4.
- Ivan
- aka: Ivan
Re: Datsun 260c
So another busy day again fixed the headers as the steering rods were hiting them.
Datsun 260c
- Ivan
- aka: Ivan
Re: Datsun 260c
Ohh and this as well
https://www.youtube.com/watch?v=Yy1k0IatfDg" onclick="window.open(this.href);return false;
Datsun 260c
Re: Datsun 260c
Good job, doesn't sound like it's running on 6 though. What was the problem with it not starting?
