Ute X-member is now on its way (thanks Kitch) so yay! Now, I have been asked to so am trying to track down some engine mounts to suit. Again, if anyone has any or can point me in the direction of someone who does, I would be very appreciative.
- Braasy
braasmonkey
- aka: Braasy
the mount shop should have some, or get hold of brock at bnt
Dyl, not the rubber mount blocks he will be after, will be the brackets that bolt to the block, which are different on the later A series motors, from the early model A 12 brackets Braasy will have at the mo.
ah, that makes sense. in that case, mount shop is no go
braasmonkey
- aka: Braasy
Kitch is correct. Have the rubbers, not the metal mounts that bolt on between the rubbers and the engine.Kitch wrote:Dyl, not the rubber mount blocks he will be after, will be the brackets that bolt to the block, which are different on the later A series motors, from the early model A 12 brackets Braasy will have at the mo.
I think I have a collection of A series steel mounts. None will be off a ute, but you're welcome to grab the box, and see if anything works?
braasmonkey
- aka: Braasy
Cheers for the offer but Kitch has come to my rescue againBartman wrote:I think I have a collection of A series steel mounts. None will be off a ute, but you're welcome to grab the box, and see if anything works?
Thanks again Kitch, and x-member has now arrived. Yay!
braasmonkey
- aka: Braasy
Engine mounts have arrived, now have to organise a time to get them and the cross member mounted. Recoring the existing radiator and touching up, need new battery as compression too high for current wee battery. New headers to arrive (should have been here today I would think) and new boot rubber to put on. To source new water pump, alternator, water temp housing and sensor, and fuel pump (so new engine has new bits attached to it lol). Still hoping to have car at least up and running come Akaroa (albeit with a spotty paint job for now), but hopefully well run in and with carbs up and running. Thanks go out to Kitch for his 1200 parts archive
Anyone know where I could find an electronic distributor for my wee car? Understand they are hard to come by these days...
- Braasy
- Braasy
Hmmm... Just about to advertise my spare EDIS kit for sale - could be ideal for your application, especially since motor is currently out of car.
Here is a link to one of the sites I did my research on
http://www.autosportlabs.net/MJLJ_V4_ve ... tion_guide" onclick="window.open(this.href);return false;
Forgot to say it is COP type (coil on plug) have a spare EDIS control unit too.
Coils, VR wheel, VR Sensor (cant find, but its here somewhere), fuel cut relay thingy etc
