Page 20 of 27
Re: VG and SR killer 510
Posted: Mon Aug 13, 2012 11:30 am
by dan1200sss
Na just widen your 7s up, it will be the same price anyway, I'm not breaking up this nicely sized set of rims
Posted: Mon Aug 13, 2012 12:59 pm
by niccy
Lol yes boss
Posted: Tue Aug 28, 2012 12:18 pm
by 85_Z31
Hey Dan
here is how my diff looks with the finned rear cover and drilled out for 10mm bolts
That rear cover is a 2 bolt z32 NA version
Posted: Wed Aug 29, 2012 11:35 am
by dan1200sss
Ah I see, looks good to me, it's not getting a bit to thin in the casing when you drill and tap the diff housing? (I haven't compared the wall thickness off the casing where the cover bolts between short and longnose r200s yet) i assume it's about the same?
Posted: Wed Aug 29, 2012 1:10 pm
by 85_Z31
its heaps thick in there, and its only drilled out 1mm bigger than before because the rest of it is thread which gets tapped into it
Posted: Wed Aug 29, 2012 3:51 pm
by dan1200sss
Sweet sounds good
Posted: Wed Sep 05, 2012 8:59 pm
by 85_Z31
Here is how your diff looks dan
Diff case drilled and tapped for M10 bolts to suit a late style cover
Backlash nicely in spec at 0.17 - after some re shimming
if you look close you can see the M10 bolt.
Posted: Wed Sep 05, 2012 9:40 pm
by dan1200sss
Siiiick, I should get it one of those Greddy high volume covers for it
Posted: Wed Sep 05, 2012 9:46 pm
And fit a pump and cooler for it too.
Posted: Wed Sep 05, 2012 9:55 pm
by 85_Z31
With a big cover on the back it won't need a cooler, mine takes nearly 3 quarts of oil, with my old cover it only took about 1 & 3/4 quart bottles. And the Greddy covers hold heaps more than the Z32 Covers
