oh and the internals of the ca are mostly the same as what the yatala headworx b110 run (same pistons, rods and bearings) i may oneday look at getting a head excessively done up but for now i believe it will make more than enough power for me, we built this to run upwards of 20psi ( would like to have it tuned to 25psi ) the specs are as folows:
-acid dipped ca18det block torque plate bored to .5 oversize to insure bores are tru
-rare 4port head fully rebuilt with mild cams, adjustable cam gears and blue gates race belt.
-Tomei 1.5mm MLS headgasket & ARP headstud kit
-custom CP pistons
-spool 700hp forged chromolly HBEAM rods and ARP bolts
-ACL race bearings
-Fully preped, grubscrewed, balanced crank.
-brand new genuine oilpump
-Tomei chromolly race flywheel (fully balanced to the botom end)
-excedy heavy duty clutch (balanced) also have an osgiken lined up for it now
-custom alloy intake plenum, has bellmouth velocity stacks inside
-steampipe topmount manifold
-genuine greddy/trust tdo5h-20g with responsive .75 exhaust side (now back to mint condition no thanks to rob the most shocking engineer iv ever had the misfortune of meeting)
-genuine HKS 40mm 4bolt gate
-nistune ecu
-z32 afm
-450cc vr4 injectors, scored a set of 800cc sard injectors cheap a while back that will go in after run in
-genuine TOMEI Fuel pressure reg, big fuel lines , 700hp fuel pump, surge tank and lift pump
- 3inch exhaust, k&n pod, vr4 front mount ( might change this to a r32 gtr item if i can find one ), KA24de throttle body.
im considering going to a larger turbo but will probly wait until after the engines run in
also im now on the hunt for a S5 thermostatically controlled oil cooler or a generic aftermarket item but it must have a thermostat.
Looking good Dan - that 510 is going scare the shit out of the majority of cars on the road!, and anyone who is luckily enough to get a ride in it once its run in too no doubt!
