Page 3 of 6
Re: why has my wheels got wider out from the gaurds
Posted: Sun Sep 19, 2010 11:06 am
by sunny79datto
?i dont really understand that.. what do you mean
Posted: Sun Sep 19, 2010 11:40 am
by 510BRE
sunny79datto wrote:?i dont really understand that.. what do you mean
where your balljoint and bottom arm bolt up together there should be four holes in the balljoint and four holes in the bottom arm make shore these holes are all being used ..............normally you cant get it wrong but from that photo the bal joint looks a long way away from the bottom arm i could be wrong chuck up a photo off bottom arm and balljoint area ....
Posted: Mon Sep 20, 2010 7:22 am
by sunny79datto
ok ill throw a photo up when i get home from work 2nite. how do i put it up so it just comes up on here so yous dont have to click a link.
Posted: Mon Sep 20, 2010 8:10 am
by Mikewazowski
Below the section where you write in your reply (Post a reply) there is an upload section (upload attachment). Browse for the picture you want and then add the file. You can then insert the attachment anywhere you want into your post.
Posted: Mon Sep 20, 2010 5:16 pm
by sunny79datto
i took some pictures hope this helps.
the bracket thing is what i couldnt use because didnt line up guess thats because its of a square headlight, the drag strut bracket?but apart from that everything matched up
Posted: Mon Sep 20, 2010 7:28 pm
by sunny79datto
does anyone that would have a idea live over the spreydon area that could come check it out after work sometime?
Posted: Mon Sep 20, 2010 8:00 pm
what time do you finish work Andy?
Posted: Mon Sep 20, 2010 8:30 pm
by sunny79datto
usally 4:00pm but can get stuck on jobs sometimes but not often.. if your keen to come havea look ill flick you some peddy $ ull have a bit more of a idea than me.. when i look under it it looks normally an wtf but maybe im missing something.. its the 1st time iv changed a front end over b4
Posted: Mon Sep 20, 2010 9:05 pm
I busy tommorrow, but I could try swing by later in the week. I finish at 320, but I could try work a bit later to save having to back track. (I work over your side of town)
You have a decent jack etc yeah?
Posted: Mon Sep 20, 2010 9:15 pm
by sunny79datto
ok yea allgood yea gota decent jack an axel stands im bout to go back out their an sit under it an scratch my head.. that bracket i have a picture of wouldnt be the problem would it?
