Bamboo fibre beats CF
http://www.greatenergychallengeblog.com ... thon-2012/" onclick="window.open(this.href);return false;
Coarse bamboo fiber
http://www.123bamboo.com/fiber.htm" onclick="window.open(this.href);return false;
R30 Guru's V8 82 HR30 Skyline
- R30 Guru
- aka: Jordy
Re: R30 Guru's V8 82 HR30 Skyline
The panel steel I'm using is 1mm thick, it seems to work well, much better than the 0.8mm I was using prior to that.sr1600 wrote:What thickness sheet are you using? It apears to bend nicely and not distort to much when welded.
Been thinking about replacing the flat section of my doors from the swage line down with new metal.
panel work is amazingly easy when you have the right gear
Projects Under Development
83 HR30 GT L31ETT
82 HR30 GT VH45DET
67 A30 GLORIA 4DR SEDAN-Resto
http://www.jurassicautomotive.com/" onclick="window.open(this.href);return false;
http://www.facebook.com/JurassicAutomotive
still handy to know how to use the gear, ive seen some horrendous stuff ups made by people even with the right gear, your to modest lolR30 Guru wrote:The panel steel I'm using is 1mm thick, it seems to work well, much better than the 0.8mm I was using prior to that.sr1600 wrote:What thickness sheet are you using? It apears to bend nicely and not distort to much when welded.
I admit defeat after welding the rear guards, After doing a little bit and realizing what i achieved in 2 months could be done by a craftsman in about 3 days. ill stick to welding thicker stuff and making suspension parts thanks.2 doors wrote:still handy to know how to use the gear, ive seen some horrendous stuff ups made by people even with the right gear, your to modest lolR30 Guru wrote:The panel steel I'm using is 1mm thick, it seems to work well, much better than the 0.8mm I was using prior to that.sr1600 wrote:What thickness sheet are you using? It apears to bend nicely and not distort to much when welded.
Cant wait to see this finished in a coat of red and black.
- R30 Guru
- aka: Jordy
[I admit defeat after welding the rear guards, After doing a little bit and realizing what i achieved in 2 months could be done by a craftsman in about 3 days. ill stick to welding thicker stuff and making suspension parts thanks.
Cant wait to see this finished in a coat of red and black.[/quote]
The jury is still out s to whether to paint it up as a Tomica replica or to use my own graffics
83 HR30 GT L31ETT
82 HR30 GT VH45DET
- R30 Guru
- aka: Jordy
Update #3
Here's what I've been upto since I went back to tech on Monday.
Should have this side sorted by the end of the day tomorrow then I need to bend up the rear panel and work my way bacK around to the front, Or I may fold up the rear panel then go straight around to the front and work on the splitter
83 HR30 GT L31ETT
82 HR30 GT VH45DET
WOW, thats amazing work
Outstanding work dude!
What wheels are you running?
- R30 Guru
- aka: Jordy
Not the one's that are on it that's for sure
Am pretty keen on something like these
83 HR30 GT L31ETT
82 HR30 GT VH45DET
I love the bodywork you're putting in.
