Im assuming the stubs axles are standard 1600 so small spline (23.5mm Looking at your vernier)
Companion Flanges must be the large spline (26mm)
This would make sense as they slip over each other but still turn
R200 Conversion companion Flanges Question
Re: R200 Conversion companion Flanges Question
Do you want to swap the ones you've got for some small spline R30 flanges? I'll whip one off tonight and have a measure up.
If that solves my problem sounds good to me, only thing i do notice there is two different size 3x2 flanges by the looks as well.DJZ wrote:Do you want to swap the ones you've got for some small spline R30 flanges? I'll whip one off tonight and have a measure up.
These are the R30 ones I removed tonight, PM me if they are going to work for you and we'll work something out.
Inside the lip on the flange is about 116mm, the spline size is around 23/24mm.
- aka: Dan
own those man! Before someone else does lol
It seems these particular R30 ones are hard to find
Sounds good DJZ Spline is definately fine drop us a PM with what you want for them. (And also if there is the mating housings there also)DJZ wrote:These are the R30 ones I removed tonight, PM me if they are going to work for you and we'll work something out.
I also picked up some more CV shafts last weekend so will run a measure over them tonight, hopefully there is a matching Outer CV Joint Housing to suit the 3x2 PCD among them.
I hear youdatsunboy wrote:own those man! Before someone else gives you some lol
It seems these particular R30 ones are easy to find anywhere
Are these the ones off that car you were parting out? As I'm still after some and possibly axles as well...
Right so a few measure measure again
Datsun 1600 companion flange measures 24mm Internal
CV axles 106mm OD so suit the r30 flanges (The ones I got on the weekend are also the same size)
Large spline flanges (27mm)with 106mm CV
Large spline (27mm) flange next next to an inner cv flange similar to the r31 pictured further up the page.
So to convert a 1600 with the standard stub axles (24mm) need exactly those r30 companion flanges
Some 910's with CV rear ends also had the same flanges.
- aka: mahony
I have put an r200 long nose lsd in my 510 sedan. I used a r31 turbo 2 way clutch pack lsd, z31 rear hubs, discs and callipers (5 stud), had to source custom bearings for the hubs to fit into the rear arms (saeco). Z31 turbo outer cvs (4 bolt) and custom built rear half shafts machined from hardened steel. I spent endless hours researching to get it all together but the rear end is solid and hooks up real good. I dunno if I could help you but let me know if you need any info..
'71 p510 sedan s14 sr20det
