CRAIGS 510 1600
- DylPhil7
- aka: DylPhil
Re: CRAIGS 510 1600
nice man, how much power you hoping to get out of it?
- Msdato
- aka: Jo
Re: CRAIGS 510 1600
You should most def come down in Oct for labour weekend, show off some datto talent, Looks sweet man
[MSDATO] B110 74 Sedan.
[EPW627] pfl S14. My other better-behaved child.
Re: CRAIGS 510 1600
You can do it Craig.
I reckon the word can't means can't be fucked!
- Brnwgn
- aka: Hayden
Re: CRAIGS 510 1600
do it do it!!
- hsepwr
- aka: Craig
Re: CRAIGS 510 1600
haha id love too but i still got a lot of work on it especially now that it has the 4 pots on the front and disks on the rear i am up for a cert now as I need a wof and ive got alot to do engine exhaust , New brake lines etc
Next year might be a goer
Re: CRAIGS 510 1600
You can do it Craig. My car has no engine, is on blocks, and has structural rust, and I plan to bring it on the cruise. Just find a dodgey wof guy. I know one guy in the bay who might be sympathetic to your cause.
510BRE
- Area Reps
- aka: shane
Re: CRAIGS 510 1600
hey craig i got a spear seat to akaroa am leaving early thursday and back about tuesday
- hsepwr
- aka: Craig
Re: CRAIGS 510 1600
Latest update
I have been very slack and have all of a sudden given myself a kick up the arse to get my car back together.I had an operation on my arm in June and was in cast 3 months and was unable to work on car but I have been out of it for 3 months and still was being slack so its time to get back into it.
I sent the motor to a Very good engine builder in Hawkesbay here and he got the block and head and CC'd it and skimmed a bit off the block to raise compression, acid dipped everything, machined and balanced the crank, machined the bores, measured everything and lightened the flywheel a little bit more and I have since got it back and painted the block and matched ported the extractors to the head because they are shit Coby ones and were so far out it was not funny.The cam is going to franklins in the next week or so for what they call a stage 6 grind which means bugger all to me as im a joiner not a mechanic and dont understand cams at all. I am ordering the rings, bearings, oil and water pump and gasket set in the next week or two and then throwing it back together.
Re: CRAIGS 510 1600
Yeah those coby headers aint flash on the port matching front. It doesn't help when the ports in the head have been worked also.
BTW, it's less than 12 months untill the akoroa cruise. You need to start saving/making plans now! That cruise is unmissable.
- hsepwr
- aka: Craig
Re: CRAIGS 510 1600
Yeh thats true but the flanges on the extractors needed about 5mm the whole way round.It must have been like trying to piss through a straw when they used to be on it
