The original tie rod ends have the wrong taper to sit in the S13/C33 knuckles so I got new R32 stuff which is the same as what I'm running in the black car, the rack ends go straight into the S130 power steering racks. It's missing a banjo bolt, thought I had one but it's the wrong thread so I'll try and track down a new one during the week. I've got a slight problem with the banjo bolt on the caliper hitting on the very top of the sway bar link or being very close to it, haven't quite thought of a solution yet, I might chop down the spacer in between the bushes slightly to see if that helps,
Also got some new cap screws and nylocks for the knuckle to strut bolts and mucked around with the intercooler piping a bit, I've chopped the top pipe and rotated the bit that goes into the cooler a bit and the other end looks like it's going to work okay, I might have to shorten the pipe that goes into the turbo outlet slightly, it's been cut on a bend and is pretty yuck.
