I'll get some photos of it over the next couple of days but basically it's a 1983 NZ new t top 2+2, it's had the facelift bumpers and a few other bits removed and now has an RB25DET from (I think) an R33 Skyline sitting in it, I made the engine mounts and sump for it a few months ago.
There's a bit of a list of jobs but I'll post up pictures as I go through them. The first thing that I did was mount the power steering reservoir, I drilled two holes and put rivnuts in then used the old bracket off my black car as it'd already been shortened. Pictures to follow.
It's getting fitted with S13 coilovers, he has purchased some 2nd hand BC reds. I did some measuring and a quick CAD drawing to see if I could get away with not slotting/welding up one of the bolt holes in the rear like I did with my black car and it turns out that the S13 pattern fits inside the original pattern with a bit of room to spare, I might make up a steel plate to go over the top of the strut tower just to spread the load a bit hopefully I won't have to muck around with doing anything to the original bolt holes.
Cut out a drilling template on the mill, the red strut top is the S13 one from the BCs and the silver one is from a set of R31 coilovers I bought ages ago.
