Greg i used a 15/16th master on my 610 coupe, I just cut off the very end of the nipples and drilled 2 holes in the strut tower for bleed line access.
Yea possibly Ill have a meaure up and see what we can do. Wanting to use the 7/8 m/c if I can as its brand new and has nipples on the right side. I think the 15/16 one would need a rubuild before use as I have no idea on the condition of it. Akaroa is the target but have a lot of things to do to get it there. Will take all the help I can get!Bartman wrote:How much too big is the spigot Greg?
Maybe we could turn down the O.D. of the MC to make it fit?
The top and bottom holes look to line up, is there a 720 adaptor like the 610 one? Could you Bore the Adaptor to suit?
I installed my Bluebird MC completely DRY and managed to get it bleed up just using a power bleeder on the air compressor. I don't think your going to have any problems, as long as you bleed it first you won't need to go near the bleed nipple. I don't think my Z 15/16th master even has any bleed nipples at all.
That's also what I was thinking Vaughan will see how much needs to come out before it fits in nice and snugclassicdat wrote:The top and bottom holes look to line up, is there a 720 adaptor like the 610 one? Could you Bore the Adaptor to suit?
Greg and I slaved over his cross member today grinding out all of the original mounting points for the trailing arm's so that we could fit our "JAG" cross member kit
(JAG = James , Adam & Greg)
Pics for greg as promised
Nice work guys.
What are you using for adjustment bolts?
James is going to draw something up and we'll get them custom made
torqued wrote:Nice work guys.
its going to be like a normal bolt with a taller head - with a hole in it for the Cap screw/stud for adjusting the camber and toeDatto_610 wrote:James is going to draw something up and we'll get them custom made
Sounds like you've got it all sorted.
Good stuff guys
Good stuff guys
