Out at James' again today. Borrowed Brendan's mustache bar so we could test properly the rear crossmember. Needed the diff in there to keep the crossmember from sagging down and throwing off rear camber. With my cut factory springs the ride height is pretty much perfect. But need new custom springs as I need a spring rate 1045lbs(this gives the equivalent of 275lbs with the leverage rate of the rear control arm) To match the front perfectly.
Re: Datto_610's 180B Ride height set(doesnt need more slam)
Sweet dude. You should post some pictures of it lowered
P.s. You have a facebook notification
doesnt need more slam. wash your mouth out. at least get rid of that muscle car rake
Coolness factor continues to climb, great work Greg, will we see this on the southern cruise?
Looks sweet mate, get it running!
What do you mean Muscle car rake?z181200 wrote: least get rid of that muscle car rake
torqued wrote:What do you mean Muscle car rake?z181200 wrote: least get rid of that muscle car rake
Haha once we rolled it back in the garage the back came down a bit more as the driveway was a bit uneven.z181200 wrote:doesnt need more slam. wash your mouth out. at least get rid of that muscle car rake
Thanks for your comments guys. Really need to get stuck into this fuel line, been putting it off for like a year. Anyone want to do it for me???
Are you doing it in bundy tubing? I can borrow a bender and a flaring tool for you if you need it.
Re-routing it might be the go, remove some of those sharp-as bends. I doubt you will ever get that 3/8" bundy to perform the amazing feats it would need to to follow the path of that 5/16" stuff. Alternatively, just use the original 5/16" size tubing, it's good enough for most factory turbo jappas.Really need to get stuck into this fuel line
