gingofthesouth's Orangatang 510
gingofthesouth
Site Admin
aka: Ging
Re: gingofthesouth's 510
Post by gingofthesouth »
SeEn-ThE_lIgHt wrote:Alot of work under that orange skin, good work fella! It must be hell frustrating to be so close, yet so far away..
Number-plate treatment could be fooled for factory, lush.
1 point of wonderment..why didnt you throw a patch in where the old interior door locks were instead of leaving the lump? Would have been easier than making that penny-patch haha!
What engine was in it when you got it?
Yeah, kinda depressing seeing it sitting there almost done lol.
Um, I guess at the time I thought it would be nicer to keep the lines. not sure why lol
The more I look at my car I regret doing a few things. Like I regret my wheel choice. I regret keeping the drop tank. I regret going for a white interior (although the interior looks awesome to me, I think black with the orange considering all the black and orange theme of the rest of the car would look better)
Mikewazowski
aka: Michael
Post by Mikewazowski »
gingofthesouth wrote:The more I look at my car I regret doing a few things.
The great thing about cars is that if you don't like it, you can always change it later on :thumbsup:
gingofthesouth
Site Admin
aka: Ging
Well I am back into it. Cleaning my dash and putting it together. All I can say is to those working on your Datsuns, please dont half arse it. It means that when somebody wants to do it properly they have to clean up your mess first haha
But seriously, I have just spent the last 3 hours cleaning al the glue and shit in my gauge cluster because somebody broke the tabs on the perspex covering the gauges.
The metal plates that lay on top of the dash between the dash mat and the windscreen look like they need repainting etc.
Any ideas on what is best to do here? Powerder coat, or spray paint fine?
mint16
aka: Brendan
Post by mint16 »
Theyre factory spray painted, Im sure they will look as good as new with a clean up and fresh coat 8-)
Any updates on the steering box?
gingofthesouth
Site Admin
aka: Ging
mint16 wrote:Theyre factory spray painted, Im sure they will look as good as new with a clean up and fresh coat 8-)
Still trying to track down the bearings. I have an NTN part number though.
NTNSF0454
Thanks to Bazza from Datsport for the number.
These are what I need to rebuild the steering box:
2 each bearings w/cup Part #NTN SF0454 or #NSK VTAA19Z-3 (Nissan# 48190-21000).
1 each sector shaft oil seal Part#PHLE AE1244N TC 24 35 7 (24=ID&35=OD&7=thickness all in MM)or NDK 48137-16500 (Nissan# 48137-16500).
1 each worm gear oil seal Part#NDK 7890 485 48029-04100 (Nissan# 48029-04100).
mint16
aka: Brendan
Post by mint16 »
Would it be worth buying through Bazza at Datsport?
Id be interested in buying a set for myself, Ive bought from Datsport before.
gingofthesouth
Site Admin
aka: Ging
he is short on them too. He purchased a whole heap from Japan and is down to his last 4, and has three boxes to rebuild so he is short. Otherwise I would have :D
I will make enquiries tomorrow since i know the NSK number now too. Bazza Just gave me the NTN one.
Datto
Post by Datto »
you could try bearing wholesale Ph: 09 570 4195 that's the only place i could find bearings when i rebuilt my steering box but that was for a 120y and i think they use NTN numbers
gingofthesouth
Site Admin
aka: Ging
Well today has been frustrating. Finally started putting the sounds in. Mounted the mid woofers. Went to mount the tweeters into the rea panel below the rear window which I had an engineering firm cut out four holes for me. I marked 4 little x marks for the center of the holes and said I wanted 48mm holes cut to fit in the tweeters which were 47mm with the mounting lip out to 51mm.
What did they do??? Cut 51mm holes ffs. Now I have to make new mounting plates to attach to the back and cut my own 48mm holes in those plates and flush mount the tweeters. All these sorts of fuck ups are really delaying my progress.
Then I noticed this which just made me want to smash my datsun into pieces.
The last panel beating job on my Datsun was the rear panel that needed to be swapped from the spare car. We were really rushed at this time to get the car ready for the painters, to get the car at my wedding . With me pushing him he has welded it in place, then used bog to skim it (when I asked for no bog when possible, should have been lead flowed grrr!). Well atleast thats what i think has happened as it is right above where the weld is (as can been seen when looking from the otherside of that panel.
Looks like more fucking money needs to be spent to get the body mint. Its my shitty luck with this car.
skdmrx
Post by skdmrx »
weow weow.sucks dick but its not your shitty luck with this car.2 steps forward 1 step back is what it takes to build the car you want.problems and over coming them is why we build cars! its a bugger that its other peoples lowsy work holding you up tho. chin up lad
