gingofthesouth's Orangatang 510
Soo here is my rebuilt thread without the bullshit.
1972 Datsun 1600
Purchased a couple years back and looked like this: Under what looked like a nice wee car was possible the worst case scenario. Rust for Africa, nothing lining up 100%, overspray on everything.
Before we get on with the build thread here is what the car currently looks like: Time to rebuild.
Stripped almost everything out of the car and took it to sand blaster to get engine bay and under car done: The result was SMH material. It showed the engine bay had been full of rust and bog. More importantly it made it extra clear how bad the front end damage was: And rust in the sill caps: So it was decided to go over the entire car bit by bit. The first and only bit of good news came when we removed all paint off the roof and pillars to find no rust there.
So it was onto the doors which I wanted shaved, and the side mirrors removed: This continued for all 4 doors:
1972 Datsun 1600
Last edited by gingofthesouth on Wed May 22, 2019 2:35 pm, edited 2 times in total.
Re: gingofthesouth's 510
So this continued for all 4 doors which also were full of rust and needed new patches put in on 3, and a new door for the 4th.
Front passenger door needed replacing as it was buggered and absolutely full of bog: Shaving and rust repairs:
gingofthesouth's Orangeatang 510
Now other bits like rear guards and boot:
YUCK!
Last edited by gingofthesouth on Tue Mar 13, 2012 12:56 pm, edited 1 time in total.
Much better!
Now for the Boot:
Drop Tank area of Boot:
Because of the shaved doors I did not want to spoil the lines by leaving the petrol intake where it was. This was removed from the side and placed behind the number plate:
Sills needed replacing:
Some more door repairs:
Will finish off adding the rest of the build tonight.
Floor went from here:
To here:
And finished like this:
Whole right rear guard needed replacing as the previous job was a hatchet job!
The door locks needed filling in and the bolts for the seat belts replaced with nuts welded in on the inside! Repairs to the front water drain area: Front guards needed repair: Take the paint off and you will find bog! Yuck this has to go!
The front.
Well we purchased a spares car to use the front off. Had that sand blasted and used spot weld drill bits to remove both fronts and swap them over with some other rust repairs on the way!
Front removed from spare car: All fixed and ready to go! Front off the proper car ready for the other front to go on: Front on, valance on, guards on etc and sealed:
Under seal done!
Car mostly finished and ready to go to painters:
