SIK521
Mr_President
Re: SIK521
Hahaha cheers boys, im trying to just keep on truckin on it. want it going asap. I will try and do as much as i can before the money side of it takes over, then it will be a waiting game. Still plenty to do before then though
Re: SIK521
Good times lastnight dude.Great to see the ute moving Get a video up!
Heres a lil something to check out
http://www.cardomain.com/ride/706389" onclick="window.open(this.href);return false;
- Dattodevil
- Datsun Addict
- aka: Damo
Re: SIK521
I've got one for ya
- Josh
- aka: SeEn-ThE_lIgHt
Re: SIK521
Like its making sweet, sweet love to the ground.
Youd be rapt!
Youd be rapt!
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
Re: SIK521
lookin good bro. Keen to see more updates
Mr_President
Re: SIK521
ok, Finally got some more updates. Got my hubs and adaptor plates for my brakes back from john and did a test fit of the turbo r33 front brake setup and then fitted my new wheels to check clearance. They all fit perfectly with only minor inner fender rub because it goes so low. also started making my own steam pipe extractors to move turbo foreward away from the firewall as i have reset the motor into the firewall. Got all the bends and bits i needed for $59incl, i was stoked that it was so cheap. Came out pretty well so far. Here are some pics.
john fancy adapter to bolt the rotor to my hub
My new wheel and brake setup
Floor cut out to fix rust
set of extractors im making
Re: SIK521
Also agree you mush build car/ute around wheels as those are sik for a SIK521
Re: SIK521
Re: SIK521
those wheels suit the truck something fierce
and that manifold is
Mr_President
Re: SIK521
Got the steam pipe bends from a place called Taylors on fitzgerald end of tuam st. I got some leftovers if you want some wal. Yeah i like the wheels to and have to make the rear wheels fit as they are 18x9.5. This means i have to chop the whole rear of my ute off and make a new box section rear with narrowed chassie rails so that i wont have to flare the deck to clear my wheels. Alot of work but its worth it. I will make a start soon on that.
