Mixed results today....
Got my new heater valve & reducer pipe filled, and tightened all the hose clips, and filled radiator.
Fitted my techno racing wheels and dropped car onto ground for the first time in 2013!
Fitted new gearbox output seal, and went to fit drive shaft...
too long by 50mm....
Spent an age trying to get crank speed signal sorted, eventually got it sorted, so spark
followed soon after.
Connected up injectors, and tried to fire it up, played around with
a few settings trying to get it running, would fire but not really run properly, unsure if
it has issues with ignition timing, over fueling or what..... did not get too far before
the battery went flat. when it ran, it did not make any strange noises, and ran
pretty smooth this is first time for this motor & ecu driven spark
once battery charged I might try again and throw the timing light
on just to ensure it is not ignition, and probably just fuel setting like injector time,
or after start enrichnment or the likes.
I will give myself a pass mark and open a beer anyway
http://www.youtube.com/watch?v=Oey8dXeV ... e=youtu.be" onclick="window.open(this.href);return false;
