Picture-less update, don't expect any comments, just writing this for my own
benefit to keep myself thinking I am progressing with this damn coupe!!!....
Mocked up front seat mounting, now using the Z rails rather than the b110 ones,
should be a bit simpler adaptor the rails to the floor mounts, rather than adapt
the B110 rails to the seats. Also have brought another set of Z seats that will
hopefully be OK in the short term, then I can get my scruffier ones overhauled
off line when I can justify it / afford it.
Removed wiring from firewall to boot area. Ran 2x new heavy (8ga) cables through
pillars & roof edge cavity from boot to the firewall, with new dedicated feed to
the headlight relays and also general 12V power supply network.
New Fuel start signal from relay to new 50A heavy duty relay I am mounting in
behind the rear tail light plastics. Upgraded all the fuel pump 12v feeds to heavy
oxygen free 10ga wires minimum. Awaiting a gold 30A fused distribution block to
turn up which will feed the new 12V circuits. Fastway have managed to take 8
days so far getting it from chch to Timaru.....
Should have the ECU back from Scott @ Embedded Design next week. Should be
good to go with new onboard MAP sensor, new ITB tune base maps, tacho circuit,
and new bluetooth adaptor for Android on the fly megasquirt tuning/diagnostics:
https://play.google.com/store/apps/deta ... dash&hl=en" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=kR3cg38tGOE" onclick="window.open(this.href);return false;
