Yeah think that's the plan. Actually not too far away compared to what I thought...... Rear end only needs bump stops fitted.
Front just needs decent springs.
Lewis has the interior.
Just wiring and engine. .........
Luke's 1200 Coupe
Re: Luke's GA16DE Coupe...... SLAMMED AT LAST
1972 1200 coupe KB110
due to new year resolutions/ mostly health issues........... no drinking.............today i stripped down the front s13 ca powered callipers......... (admittedly dropped an austin mini full subframe out to deal with too as the gbox to engine oil seal has let go and is binding the clutch plate annoyingly. fuck the brittish, honestly.
and found that i have 2 full rubber seal kits ready to go for the re-kit of the callipers (drinking sometimes works)
they are fully stripped and ready for paint, and if anyone cares to read said post......
big curiousity with the cert rule on bump stops.........
i know full well the WOF law is fit a finger between chassis and Bumpstop.....................
what i want to know is what can i get away with mm wise (keeping in mind i will be going for cert)
any help appreciated
(and yes, i know where REAR bump stops go now, i have learnt. just after advice
Quoted for truth!luke wrote:fuck the brittish, honestly.
You've come a long way since first we met Luke. From a "I have no idea wtf I'm doin, hey it's 11am, lets open this bottle of appletons", (That was actually exactly how the first time we met went too) to someone who actually sounds like they know what they're talking about.
BUT, since you learned on Datto's, you'll perhaps find the English tin not so rewarding to turn spanners on...............
IDK about your bump stop issue. But it makes me smile that you're wading back into your coupe with a renewed gusto.
The brittish can go get f@#ked. Honestly it's awful.
But yes. ......
the coupe is receiving a little love atm......you really should visit
Iv adopted Brendan's ideas of accomplish something every day. And so far it's paid off!
Calliper part painted tomorrow and rebuilt tomorrow night. ....I hope. .....
But yes. ......
Yes I'm long overdue to come over for a visit.
the finger to bump stop wof rule will depend on how fat your finger is at a guess,
IMPORTANT MINI STUFF, have you got the flywheel off yet? there is a special puller that attaches to the flywheel with 3 bolts and allows you to tighten a centre bolt that will then pull the flywheel off, it will be near impossible to remove the flywheel by way of a prybar from the rear through the starter hole, if the flywheel hasn't been removed recently it will be tighter than you can possibly imagine, once its off though, and you remove the alloy housing the seal goes in, you will note 3 gears that transfer the drive from the crank to the gearbox.. DO NOT DO NOT DO NOT get the centre gear round the wrong way when putting it back in, the shaft is longer in length on one side, if it goes in back to front it will blow a hole in the alloy casing when you try to tighten the casing back up again.
sorry I cant help with your bump stop question.
haha dont worry, jeremy has the fancy tool flywheel puller2 doors wrote:the finger to bump stop wof rule will depend on how fat your finger is at a guess,
Dyldo Phillips on here has that tool too. What a fucken joke of a system.luke wrote: haha dont worry, jeremy has the fancy tool flywheel puller
When he is back from holiday we are finishing putting his POS mini back together and on Trademe it goes.
Not sure on the WoF requirements, all I know is that the car can't rest on them and must prevent the wheels hitting the chassis should the suspension fail, for cert. I have been talking to the cert guy here regarding my new 280zx coiler setup for my 510 and he was saying that since he can't measure up the bump stop clearance (i have internal bump stops) that he will have to drive the car with the springs off or I need to get external bump stops.
In other words, he will measure the distance between rest height to the bump stops and check to see if the chassis will foul if the suspension fails.
Probably doesn't help you but thought I would share anyway.
Last edited by gingofthesouth on Sun Jan 04, 2015 10:56 am, edited 2 times in total.
Simms is always buying scrap metal.
fill the fuel tank with sand before you take the mini's down and get more $$$ to spend on the Datsuns.
