dan1200sss ca18det datsun 510
dan1200sss
Datsun Driver
Re: VG and SR killer 510
Post by dan1200sss »
id planned on having it done by akaroa but a few further upgrades and alterations pushed the on the road date back a month or 2 so hopefully by christmas time if all goes to plan
DylPhil7
aka: DylPhil
Post by DylPhil7 »
sweet!
also good to hear your having an uncut grill :D
dan1200sss
Datsun Driver
Had a but more progress on the weekend and yesterday, finally got around to getting the arp flywheel bolts carefully machined down by 5mm so the pull up tight without bottoming out in the crank seeing the aftermarket flywheel is thinner than factory. I torqued & Loctited it all up so it hopefully won't come loose. Threw the box in and fill her up with redline. Then made up the rest of the 3" exhaust and welded it up to the dump pipe. Not much to do now, need a decent brand oilpress gauge and possibly oil andcwater temp gauges also but mostly need just a oil press. Oh and a sandwich block for fitting the sensors into.
dan1200sss
Datsun Driver
Oh yeah and got the rims in a bit by having my mate from Hamilton-jet machine the backs of the rims to remove some offset, was a freebie too which is mint.
dan1200sss
Datsun Driver
Been a bit slack of late, get my license back finally on the 26th of Jan so starting to get onto it again, the only things now left to do/get are: Samco rad hoses, t-bolt clamps, wideband kit, raise the front 15-20mm for sump safety , then just fill with oil and start up. Here's the filters I got for it
Dattochriswagon
Post by Dattochriswagon »
Sweet dude, You be on the roads for summer
Txt me when you fire it up. I wanna be present for such an auspictious occation.
gingofthesouth
Site Admin
aka: Ging
Post by gingofthesouth »
Very nice, keep up the good work!
z181200
Datsun Mad
Post by z181200 »
You just want another ride down a narrow street with cars on each side Simpson!
hell no!
I don't care if I never ride with this cunt again. He has a deathwish! Although I might if I'm oiled up with blue diesels. (Which I very seldom drink nowdays)
