Depending on your cert man, you may still have issues with the rear travel. I had to make sure it didnt bottom out with people in the back, so unless you have super stiff leafs, I suspect 15mm wont be enough. Did he give you any guidance on what is satisfactory?
Worth a shot tho! Like i said, will be different for each cert man
Re: Kitchs 1200 Coupe - 99% done....
I have reset rear springs with an extra leave added, it is pretty firm.
I could probably grind another 10mm off the bump stops easily enough...
One side is sitting a tad lower than the other, so might have to point him towards the 'higher' side!
Ooooooooooooooooooooooooh yeeeeeeeeeeeeeeeeeeeeeeeeah!!!!!
That's awesome man!! Congrats!
I hope to have mine going in maybe a year to be second best at an akaroa shoot out............ said everyone on this site...........
just saying itd be neat to see both quad throttle toys at full rpm.......................
congrats on so many levels
1972 1200 coupe KB110
sounds like you need another project lol , well done.
Think you should change the title to "100%" cheers, well done. Can't wait to see it at Akaroa THIS year.
Bernie and Chris.
Bernie and Chris.
- aka: Braasy
A Datsun project is never 100% donechris_g1 wrote:Think you should change the title to "100%" cheers, well done. Can't wait to see it at Akaroa THIS year.
Bernie and Chris.
-- Nick/Braasy
braasmonkey wrote:A Datsun project is never 100% donechris_g1 wrote:Think you should change the title to "100%" cheers, well done. Can't wait to see it at Akaroa THIS year.
Bernie and Chris.
-- Nick/Braasy
Correct Braasy, still a few tidy up jobs to finish;
> Needs a catch tank installed
> Electrical fan logic needs sorted (as relay wont switch off once ignition off)
> Front number plate surround
> few bits of chrome to be renovated
> missing rear bumper mount outer tabs
> few other bits & pieces
Main thing is servicing it & getting it reliable, so I can take it for cruises without fear of overheating or breaking down
Yes Akaroa 2015 - you better believe it!
