I'd take out those crush tubes. and fit a rubber washer under a washer under the head of the bolt. Or some such.
you need to try keep any part tied to the engine, rubber isolated from the body. Those crush tubes will clamp up hard, transfering vibration from the zhorst, to the bolt, which could transfer to the Xmember, and into the body.
Re:
Fixed that for you.Datto_610 wrote:Yeah aight then. The crossmember is solid mounted the body anyways....
Crossmember has cert man approval! So better whip it back out to rattlecan it black and get that cert plate ASAP!
Attacked the crossmember with a flapper disc yesterday in preparation for sandblasting, Bart got me onto a mate of his that does a little bit powder coating so stripped the old paint etc off myself. Flapper disc made pretty short work of the old paint just jad to wire brush and hand sand the hard to reach parts
Also made a start on the sway bar bush spacers out of some flat bar I had lying around. Excuse the not so straight cuts and most probably not in line holes but I plan on tidying it up on a belt grinder/linisher and will most likely need to slot the holes as well. It's only 5mm flat so may need something thicker but will try these first.
Give me a txt when you want to sort those struts out Greg
- kartboy
- aka: Hayden
Datto_610 wrote:Attacked the crossmember with a flapper disc yesterday in preparation for sandblasting, Bart got me onto a mate of his that does a little bit powder coating so stripped the old paint etc off myself. Flapper disc made pretty short work of the old paint just jad to wire brush and hand sand the hard to reach parts
I really hope you were drunk when you cut and drilled those spacers.
- tlssunny
- aka: jesse
good call hahakartboy wrote:Datto_610 wrote:Attacked the crossmember with a flapper disc yesterday in preparation for sandblasting, Bart got me onto a mate of his that does a little bit powder coating so stripped the old paint etc off myself. Flapper disc made pretty short work of the old paint just jad to wire brush and hand sand the hard to reach parts
