I always loved the 1200, had a mate back in the day who had a mustard coupe with a worked A12. It was quick! And gave another mates worked 1600 twin cam Fiat 125 regular hidings!
Probably has a lot to do with the weight, not too many cars lighter that this puppy which tips the scales barely over 700kg
1972 Datsun 1200 Coupe.
Another sweet thing about these is the interchangibility from other Datsuns.
It will be running;
A15 (From Sunny)
60A 5-speed box (from Sunny)
H165 diff (from 1200 Ute - bigger diff that can handle SR20DET)
1200 Ute crossmember (so A15 will bolt straight in)
B310 Sunny bottom arms (bolt in more neg camber)
B210 120Y swaybar (20mm instead of standard 17mm straight bolt in)
B310 Sunny castor rods (more castor adjustment)
280ZX struts and brakes (shorter than standard, same dimensions less offset and they pull up 2.8 litre turbos dont they?)
B310 Sunny modified 5 core radiator
C20 Nissan Caravan Internally regulated Alternator
E15 Pulsar electronic distributor
just to name a few things.......
Here it is when I first got her; (I am second owner)
Original tool kit, all tools embossed with Nissan.....
Without wheels...
Wheels with new Advan A048 (same as Cheater 5
With new wheels, but too much glare with garage door open. So will take better ones on a crappier day with less sun (WHAT did I just say that??)
