R31 Struts
Posted: Sun Mar 14, 2010 9:23 pm
Well as im a bit short on money right now to progress with the next stage of my 140J i thought id play around with parts i already have.
I have a pair of R31 struts from a RB20DET Auto Sedan that i planed on using i have cut the spring seats off and slid a spare set of 140J seats on (they are yet to be welded as i havn't confirmed a hight yet)
What im wondering is are all R31 struts a hub/disc combined style setup or did some of them bolt on the back like the earlier datto ones. I wanted to change the front to 5 stud to suit a set of rims i have rather than buy new rims.
I have a pair of Z31 5 stud hubs but they are set up to have a separate disc bolted to the back.
I was originally hopeing i could just swap the hubs redrill the disc and bolt it on the back like it was before and away i went but unfortunately i can't do this with the current setup.
If there is a separate hub disc R31 strut i will probably keep an eye out for a set as converting them to 5 stud will be so much easier.
If not then i need to think of another way. Id redrill the hub/disc but its not a smooth face it has 4 indents that will get in the way.
Any ideas on how to solve this will be great. I want a stock standard looking setup so hopefully i can slip though wofs with out certifying it and also a brake upgrade to.
