Has anyone ever replaced their waterpump with a GMB unit?
I ask, as ive got one ready to go on mine, but the bolt spacing is larger, as is the centre hole.
Part number WPN11A
As a re-cap, its an A15 from a C22 Vannette.
A Series Waterpump
- Josh
- aka: SeEn-ThE_lIgHt
A Series Waterpump
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
Re: A Series Waterpump
WATER PUMP GMB GWN02A W/PUMP NISS 1200 120Y C20 1970-
WATER PUMP GMB GWN11A W/PUMP NISSAN A12/A15 75-94 WITH A/C
- Josh
Weird. Hope my B310 fan fits
Where do you work Adam?
ditch the viscis fan bud and just run a air con fan outa any large nissan ie a laurel there cheap as chips. its easy to mount them out of the way in front off the radiator and run a few wires and a switch then bam dun problem solved
PAINT THE ROADS BLACK !!!!!
- Dattodevil
- Datsun Addict
- aka: Damo
I'll take the viscous if you're not using it, next best thing to electric
- Josh
Duely noted
