rear springs captivity
torqued
aka: Adam
Post by torqued »
I seen this on a forum today
could be a good idea to keep rear springs captive when you lobe off a few coils
Josh
aka: SeEn-ThE_lIgHt
Re: rear springs captivity
Post by Josh »
Hows that attached? just welded to diff tube or locates over the ..locator?
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
torqued
aka: Adam
Post by torqued »
Dont know sorry dude. just looks to be sitting on the lower arm spring locater and using spring pressure to hold it in place to me
Josh
aka: SeEn-ThE_lIgHt
Post by Josh »
Wonder if it affects the sprung height..
Ill be looking into this as i need alot more low.
fast4motion
Datsun Dreamer
aka: Brent
Post by fast4motion »
The only way that would keep your spring captive is by raising the height of the car. Which negates the point of cutting your springs.
I think that's only been put in to allow a bit of height adjustment, and possibly the use of common adjustable coilover type springs.
torqued
aka: Adam
Post by torqued »
only if spring compression is less that the height of that spacer
old_datto_fan
aka: Mike
Post by old_datto_fan »
That's why I went with these as an alternative. Worked a treat but don't need them any more as I changed the shocks.
http://www.trademe.co.nz/Browse/Listing ... =297427617" onclick="window.open(this.href);return false;
1971 Datsun 240Z L32
1987 Nissan Sentra SR Twincam CA16DE
sr1600
aka: Mark
Post by sr1600 »
can you get these for a 1600?
old_datto_fan
aka: Mike
If you have the spring measurements, go to this page and you may find something that will fit
http://www.suspension.com/COILS_SPRING_ISOLATORS.html" onclick="window.open(this.href);return false;
