Vanette H190 mounts
jeremiahnz
Datsun Driver
Vanette H190 mounts
Post by jeremiahnz »
Hey guys,
Struggling to find a definative answer anywhere about whether the leaf mounts on the vanette H190 are the same as on a standard H150/H165?
Just trying to work out if an H190 from a Vanette is pretty much bolt up and go, apart from the width (plan is to run FWD mags so I don't have to shorten it)
1965 Bluebird 410
1976 Yamaha RD50
Re: Vanette H190 mounts
At a guess I'd say the spring pads would need to be moved. Vannette diffs are 50mm each side wider than 1200 ones, so I'd say theres going to be a bit of re-engineering required.
jeremiahnz
Datsun Driver
Hmmm I was hoping that wouldn't be the answer.....
A few guys on here run them in their 1200's from memory, interested to hear what they had to do to get them in.
1965 Bluebird 410
1976 Yamaha RD50
