Hi again more questions how much am i looking at for a dog leg 5 spd short box .
And will a 4 door 1600 drive shaft fit the j , my Haynes bible says total length is 1263.50 mm ,and how much am i looking at for the drive shaft it's the three joint type .
Thanks for all your help Glynn
1600j sss dog leg & drive shaft
- 160jsss
Violet - ??????
Re: 1600j sss dog leg & drive shaft
I don't know anything about the three joint shafts, But I do know someone who Can shorten a one piece one locally cheap.
- 160jsss
Thanks this is the sss so has the independent suspension so has the two piece drive shaft with the bit in the middle
Violet - ??????
- Datsun Mad
Its interesting that you mention the single piece and 2 piece shafts.
Ive owned 3 160Js one i wrecked and all 3 had single piece shafts. Then i know a guy who as had 2 of them both had 2 piece shafts. with a hanger bearing.
I have a spare drive shaft from a 160j i know for sure it suits a 4speed and a R30 standard pattern 5 speed cos its been behind both.
Should be find behind the dogleg.
hay..i have a dogleg for ya..and im local so we can bolt it up to check for length...
pm if interested
pm if interested
hey i hav both drive shaft and dog leg but i want the dog leg 4 my 240k
tha drive shaft is single peice but was out of a 160j sss
- 160jsss
Thanks for all with the help .
thanks to torqued i'm now the owner of a doggy
happy day
Violet - ??????
Score!
- 160jsss
Very happy Datty owner and must try to meet more like-minded people .
Just the rust, motor and little bits to do should see the road sometime
Violet - ??????
im more than happy for you to buy more off me
