i scored myself a set of drla 48mm dellorto downdarfts there choked to 34mm.
and i was wondering whats the pros and cons of downs?
and the pros and cons of sides?
any advice would be mint
cheers toby
dellorto sidedrafts vs dellorto down drafts
PAINT THE ROADS BLACK !!!!!
Re: dellorto sidedrafts vs dellorto down drafts
with downdrafts, the charge has to change direction before it can enter the cylinder.
So they aren't quite as performance as sidies. They still work well and sound good though.
the cost me a12 good deal??? they hav never been used and is there any other pros and cons
In dunno if you can get an off the shelf manifold for them, so I guess that would be a con.
- DylPhil7
- aka: DylPhil
Con: they dont look as cool
Pro: you can keep it looking original under the hood...but with more power, sleeper
Dyl Phill wrote:Con: they dont look as cool
haha a ga16 under the hood of a 1200 kinda looks outa place!!!!
next question can u mount them on a slight angle???
- Area Reps
- aka: shane
not much angle it will upset float levelsMR1200 wrote:Dyl Phill wrote:Con: they dont look as cool
Are you gonna remove the efi in favour of carbs Toby?
I'd stick with the EFI if I were you. Plus it makes the implimentation of forced induction easier later on.
ha thats the first thing that went in the bin
- DylPhil7
- aka: DylPhil
what did you do with the efi????
