I just fitted a locky to my 1200, and the diff flange is different to my driveshaft. need one urgently. I hope I can just swap the yolk over onto my driveshaft. (Providing they use the same universal joint)
Drags are saturday!
Need a vannette drive shaft to suit an H165.
unlimitedpower
- Datsun Mad
Re: Need a vannette drive shaft to suit an H165.
Couldn't you just swap the diff flange?
http://www.trademe.co.nz/Browse/Listing ... =320004405" onclick="window.open(this.href);return false;
Try this guy, he brought that C20 in Rangiora a few weeks back, I just found out he sold the diff, but may still have the drive shaft?
worth a shot
worth a shot
Thats Joe. I've already hit him up about it. I need to grab the very-near calipers and see exactly what I need.
The H series diffs run a cunty crush tube that makes it a cunt to undo and reassemble the pinion flange. I'd rather not go there if I can help it.unlimitedpower wrote:Couldn't you just swap the diff flange?
Joe's one was no good.
I need one with a 50mm spigot and a 75mm PCD.
unlimitedpower
- Datsun Mad
Ah i see cheers for that little bit of info that i will store away and remember if ever get the urge to do anything with my 140J Diff.
