510 struts into a 310????
DylPhil7
aka: DylPhil
Post by DylPhil7 »
as above...possable??? much work? cheers
nick_m
aka: Nick m
Re: 510 struts into a 310????
Post by nick_m »
I believe they will bolt up but the spindle angle is different and will give you mad positive camber I think.
Sorry can't give you a definite answer, not many people hold onto the std 1600 struts.
Also don't know if they will be much shorter than 310 ones anyway because if not theres probably not much point swapping, the brakes aren't much bigger if at all bigger than 310 stuff.
Springs are too big too I think.
DylPhil7
aka: DylPhil
Post by DylPhil7 »
reson being is ging has spare struts..
cheers anyway nick :D
gingofthesouth
Site Admin
aka: Ging
Post by gingofthesouth »
Dyl Phill wrote:reson being is ging has spare struts..
yeah I have spare struts and lowering springs ( I think they are not original 510 struts anyway)
Just seeing if they will fit his car for him.
DylPhil7
aka: DylPhil
Post by DylPhil7 »
should i just try it anyway ging? :idea:
aka: leppa
Post by dirtyleppa »
go for it man, it only takes 15min to remove a strutt anyway. worse case scenario, it dont fit
510BRE
Area Reps
aka: shane
Post by 510BRE »
Dyl Phill wrote:should i just try it anyway ging? :idea:
as long as you do all the bolts up again so it doesnt fall out like the battery :poke: :poke:
DylPhil7
aka: DylPhil
Post by DylPhil7 »
:oops: :lol: yeah but not too tight like the diff bolt i snaped off......i didnt add that into the thread...
I wouldn't bother TBH.
VL commonwhore brake calipers reportedly bolt straight onto B310 struts. I don't yet know what disc rotor to use with them though. (it quite a popular upgrade in OZ so I believe)
nzdatman
Post by nzdatman »
510 struts slightly shorter, same stub axle angle as 310. commodore calipers fit both 510 and 310 as caliper mounts are the same.
