A series Flywheel modifications.
Sell stuff
If anyone would like their A series flywheel lightened, or redrilled/machined to take a 200mm Lseries pressure plate, My Dad can do these for $50 each.
A flywheel having the 200mm plate modification can't be made as light as one using a standard clutch, as the material at the periphery is needed to bolt the larger pressure plate to. there is also an off the shelf 200mm friction plate which fits the A series (56/60 series) gear box input spline.
I should also add that it's best to start with an A12 flywheel, as they're thinner and lighter from the get the get go.
