We left it there and went to get a car to tow it with. About 40 min later we got back to the 610, I put the keys in the ignition and it fired up straight away. It ran for probably 20 - 30 seconds (long enough that I thought it was sweet) and then the idle dropped down and it died again. It started once more for a couple of seconds then died. Then it just turned over and wouldn't start anymore.
I've towed it home and it is in the garage at the moment. I'm just waiting for a bit and then I'll have a look at it.
I had a quick look and nothing seemed out of place:
- spark plug/coil leads all connected
- doesn't seem to be any boost leaks
- I can hear the fuel pump running
Any ideas of things to check would be great. I've got a few ideas but would be good to hear any thoughts you people have
Thanks in advance
Michael
