As per title I am after a ute rear end H165, 4.1 ratio or higher.
I have an H165 setup from a vanette, but it is too wider track for my application being 100mm wider than the B110 standard setup, probably a bit much work to shorten, so prefer to get a narrower one.
Prefer Chch or South island.
Even a housing and axles would probably do the trick, and I could swap my brakes, diff head & stuff across perhaps, as I will be stripping to blast and powder coat anyway.
Let me know if you can help out, as I want something in the next week or two if possible.
Kitch
