Tire size
160jsss
Tire size
Post by 160jsss »
ok before i get :pc: :pc:
I've looked up the calculator http://www.miata.net/garage/tirecalc.html" onclick="window.open(this.href);return false;
And what i come up with is something a 195 65 14 or b 185 65 14 to keep speedo in range
What i would like to know is will 195s rub on anything or should i go 185 it's for the 160j so should be the same as the 1600 180b set up want to go r30 front when i have money but can get some cheap rubber now so thinking about it now
Violet - ??????
Mikewazowski
aka: Michael
Re: Tire size
Post by Mikewazowski »
It really depends on the offset of your wheels and how low your car is.
I run 195/50/15 on the front of my 610 sedan (I think the wheels are +19 offset). Crossmember is a bit over 100 mm off the ground and they don't rub at all. I'm using R31 struts.
torqued
aka: Adam
Re: Tire size
Post by torqued »
width and offset of current rims are?
160jsss
Re: Tire size
Post by 160jsss »
Ok hope this helps on the inside there is stamped 14x6jj I'm going to say thats 14 inch then +38 that would be offset ?
Thanks man
Violet - ??????
Mikewazowski
aka: Michael
Re: Tire size
That's quite a positive offset; Have you tried the wheels on the car to make sure they clear the strut? I'm no expert but you may need to run spacers with such high offset wheels.
If they clear the strut and spring perch, I can't imagine that you would have any issues with rubbing on the guards since they are only 6 inch wide rims.
The front wheels on my 610 are 6.5 inch wide and they clear easy as. Again it all depends on how low you go as well.
160jsss
Re: Tire size
Post by 160jsss »
True see this is why no sleep and working at night is not good :lol:
I'll put the rims on tomorrow and see +38 seems a lot of offset to me to ?
Violet - ??????
torqued
aka: Adam
Re: Tire size
Post by torqued »
Its more a FWD offset
Mikewazowski
aka: Michael
Re: Tire size
Yeah best to check that you are going to be able to use the wheels before you get tyres put on.
If they don't quite fit, but you still want to run them you could always look at spacing them out.
Personally I'd shy away from that as I reckon rwd offset rims with a bit of dish look the business, but it's a matter of preference.
unlimitedpower
Datsun Mad
Re: Tire size
Post by unlimitedpower »
I have an excel copy of a really good tyre/rim calc you input your original specs then it over lays a pic of what you want to run.
It factors in and shows rim offset width tyre sizes height width speedo calibrations and also tyre stretch so it'l show you how a tyre will sit on your chosen rim.
Its really simple to use best ive found on the net so far. I don't know how to host up files but if you PM me your email (or anyone else) i'll email it to you.
I have 205s on the back of my 160J and 185s on the front they both clear easy as but they are on RWD spec 13X6" Steel rims. So that won't really help you to much.
Rusty
aka: Ryan
Re: Tire size
Post by Rusty »
Hey man upload the file to http://www.mediafire.com/" onclick="window.open(this.href);return false;
then share the link and sorted.
