This process should also work for other types of Nissan's/Datsuns which use a bolt on style rotor as the process to convert them to slip on rotors is the same.
There is huge emphasis buying impossible to find Jap DR30 Hubs or the impossible to find 1988 Z31 5 stud hubs.
This conversion will take your existing square or pentagon hubs with bolt on rotors and convert them to take a slip on rotor.
The machine work cost me about $100, and it uses the Hubs you already have, vs paying out of your ass to get other types on slip on style hubs.
My Engineer was Justin Neil, and he has done this other Front hubs that have Passed VVTA cert via Wayne Martin
Also please excuse the Idiot Step by step nature as this was written for Americans on an American forum. ( good guys nothing against them but half the time they just can't understand )
and enjoy....
So you want to fit 4 pots & Decent rotors on your 84 -86 Turbo or any YEAR Non Turbo and you can't find 88 Turbo Hubs ?
You will Need the following before you begin
Tools
1) A decent Place to work
2) Jack stands & typical hand tools for working on cars
3) Brake line clamps & Drip tray
4) Something to chock the wheels
Parts
A) Z32 4 pot calipers
B) Brake rotors to suit your z32 calipers ( there are 26mm and 30mm versions so make sure get the correct ones )
C) Longer wheel studs x10
D) Front wheel Bearing kit ( optional but you should probably do it while its apart )
E) PDM conversion Brake lines > http://www.pdm-racing.com/products/brakeslines.html" onclick="window.open(this.href);return false;
F) New Bolts for the brake calipers -
G) Machined Spacer for Brake Caliper
H) Fine washers to match the Machined Spacer
Services
you will need some time with a reasonable good fitter / turner / somebody who can operate a lathe reasonably well
Note !!!!
If you wish to keep your stock wheels with the 4 pot brakes this is possible however you will need a full set of 20mm Hubcentric adapters for the front and rear
Step 1
Jack up the car and put chassis stands at the front on a flat and level surface and remove the wheels, now is a great chance to throw a drip tray under the brake caliper and fit the brake line clamps so you don't get brake fluid everywhere.
Step 2
Loosen the bolt that holds the brake line onto the caliper , DO this while the brake caliper is still bolted down or its a PITA
after you have removed the brake line you can go ahead and unbolt the brake caliper.
Step 3
Remove the front hubs as per the NISSAN FSM, remove your wheel bearings as per the NISSAN FSM & clean all the grease out of the hubs so you don't piss off the person who is going to machine them
-- By now you should have a stack of shit looking like this
Step 4
Remove the old brake rotors from the hubs but don't throw away the rotors as you will need one later
--By Now you should have 2 fully stripped hubs to send into the engineer to be machined.
Supply your friendly engineer with the following
1x Z32 Brake rotor ( Sample for measuring from )
2x Z31 pentagon or square front hubs
1x original Nissan wheel ( Sample for measuring from )
Step 5
Have the OD of the hub turned down to the measurement shown
Once the Rotor slips onto the hub nicely it is time to machine a sleeve to be pressed onto the spigot so that the brake rotor is not going to slop around IE it needs to be Centric to the HUB
Tell the engineer to machine down the hub, so that he can then turn up a sleeve that locates the brake rotor and the wheel snug. The sleeve i had made is high tensile alloy to a 4 thou interference shrink fit.
it should look like this
NOTE
It is very Important to provide the wheel and brake rotor as a sample so that the engineer can make a sleeve to accurately locate the wheel and rotor. If you engineer can't figure this out GO SOMEWHERE ELSE
